Punto (Mk2/2b) Ceased bolts on strut - to remove drive shaft
Can you help
We are trying to remove the bolts from my Punto 2000 strut bottom in order to remove the drive shaft
Not surprisingly the bolts are ceased and are in danger of rounding
Any help / thoughts on other options for removing the drive shaft
We are doing this in order to replace the clutch:mad:
I've replaced a clutch before now just swinging the box, leaving both shafts attached. The only downside is not much space to work, I'm having same problem with same bolt atm trying to remove a gearbox. Think I'll end up just dropping it out off the shafts
Can you replace the bolts? Or are they fixed studs? Might be worth investing in a nut splitter if you can spare the bolts. I can imagine a grinder being much fun under there.
Also give them a good soak in PlusGas before anything. None of this WD40, its all about PlusGas.
have you applied either liberal amounts of WD40/penetrating fluid or Fire (never apply penetrating fluid and fire) usually one or the other helps.
I have been known to weld a cheap spanner to a bolt to remove it,
Don't even bother with WD, it aint worth it. PlusGas is where its at
Re: seized bolts on strut - to remove drive shaft
To be honest im a bit confused here
why would you undo the bolts on the strut to do a clutch?
why not undo the ball joint pinch bolt?
i spent about 1 1/2 trying to get my heavily corroded and seized into place bottom ball joints out
Luckily my strut bolts came off without a single fight - cause i'd had them off before and copper greased them up
if you can get the strut turned around enough - you can then wack the bolts out
But if a bolts dodgey and not suitable for refitting, get a new one
For £10 you can replace all 4!
Ziggy
Ziggy
:ROFLMAO::ROFLMAO:
guess you wished you had removed the anti roll bar then :D
Because it's (usually) easier.
You need decent 6 sided sockets, 18mm and 19mm, and penetrating fluid at least the day before. A breaker bar is handy..........
im not being awkward here but ive seen this way recommended before so did actually try it on a punto last year
i failed to get the driveshaft out of the hub
so null points
so my question to the team
has anybody actually achieved it
Well 4 hours later, we got them out. For those who suggested Plusgas, clean, Plusgas, clean, Plusgas, clean, Plusgas, clean, breathe Plusgas, clean, then I think this is the right answer. Also don't touch the bolt. Nut only. Thank you for the help:cool:
so null points
This is how it's usually done on Centos, and Mk1s. Undo the innermost CV joint clips (replace later with big, decent quality tie wraps). Undo the 2 bottom strut nuts, pop the bolts out (punch or podger useful). Free up the struts at the bottom just so they can move. Tug on the disks. The driveshaft should pop out of the cup. Wrap in plastic bag to keep the carp out, tie up out of the way.
It my just be that Mk2s are fundamentally different, but I doubt it.
No attention to hub bolt, TRE or bottom ball joint should be required.
