Ha after finding out what they do when fitting them with my punto it explains alot!
Anyway,
Battery - Battery tray - Crack top gearbox Main nut - Slave cylinder - Earthing Strap - reverse sensor - 3x bolts holding gearlinkage in place - pop linkage joints - Disconnect starter motor resting to one side - crack the 3 main top bellhousing bolts - Raise car up - wheels off - Drain Box of fluid - Speedo Sensor wiring - Rear dogbone Gearbox nut and bolt - Bottom ball joints / Suspension joints undone - pull shafts out the gearbox - Remove remaining underside gearbox bolts inc engine to gearbox support bracket - Dont forget to undo the 18mm Bolt holding the Gearbox Stud as well - Pull gearbox out
using a big screwdriver and 1x Bellhousing bolt
Pin the flywheel in place while clutch bolts removed
Note orientation of the clutch boss
Refit new clutch (loose)
Alignment tool to align clutch - Tighten and torque up
its then a nice long case of - rebolting everything back on once the box is back in!
Might have missed 1 or 2 steps, but i've spent 6hours today removing my gearbox, but i've have a horrible removal as you guess - lots of sezied bolts
Ziggy
