FIAT Auto Specialist Team
Thread Tools
Old 1 Week Ago   #1
shelleyamy has donated!
Need to identify this pipe please
It's for a Alfa Mito, but same engine as the Grande Punto 1.4 16v.
Just under air filter box, part in yellow box.
Credit to RuSZ for photo.
shelleyamy is offline Reply With Quote Quote
Old 1 Week Ago   #2
varesecrazy has donated!
Re: Need to identify this pipe please
Ok..
Look on
Fiatdalys
Website.. you will get description and part number
Compare fiat and alfa
Let us know what you find
Charlie
varesecrazy is online now Reply With Quote Quote
Old 1 Week Ago   #3
Quote Originally Posted by varesecrazy View Post
Ok..
Look on
Fiatdalys
Charlie
Thats my problem, looked at every picture on there, cant see it.
Old 1 Week Ago   #4
Quote Originally Posted by shelleyamy View Post
Do you need to replace the part..
Or just tracing a fault?
Charlie
Old 1 Week Ago   #5
Charlie
The airbox had a broken lug, and the sharp end of that has split the hose, causing an erratic idle.
Taped it up for now. but it run worse and cut out at first, but the ECU "LEARNT" the new mixture requirement, and now runs perfect.
Old 1 Week Ago   #6
Moderator
g8rpi's Avatar
g8rpi has donated!
@shelleyamy
Is the picture your engine as it has a modified inlet.?
The poe indicated does not look like it needs to be a moulded part. A length of standard oil and fuel resistent hose (or coloured silicone) with a gentle curve should work OK.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 1 Week Ago   #7
s130 has donated!
I had a long look a ePER the other day and I possibly found what this is.
However we need a full VIN or Type code and Chassis Number to nail the exact engine specifications.
Simple cc, no. valves, same as Punto is not going to help as there are MANY 1.4 16V Punto and Mito engines that are listed.
s130 is online now Reply With Quote Quote
Old 1 Week Ago   #8
Quote Originally Posted by g8rpi View Post
@shelleyamy
Robert G8RPI.
No, its a photo RuSZ posted, but i will have to use a generic piece of pipe if can't find an original.
Would also be good to know what the "black box" is it connects to.
Old 1 Week Ago   #9
Quote Originally Posted by s130 View Post
ZAR95500001054405
Old 1 Week Ago   #10
I think the black box is part of the butterfly, and the pipe is 77366314.
But does not show on the parts list.
Old 6 Days Ago   #11
Thought you drew a blank.. and it wasnt listed..??
Old 6 Days Ago   #12
348azeus is offline Reply With Quote Quote
Old 6 Days Ago   #13
s130 has donated!
This pipe goes to the LHS of that round black plastic component.
The question now is on the other side of that component is there another hose leaving it? Any hose could be possibly on the underside?
Also are there any wires going to the round black plastic body which looks like a diaphram of some sort?
Old 3 Days Ago   #14
Trader Rating: 10
dave has donated!
not sure what its called but a 1.4 grande punto starjet has it and wont run right if you remove it. look around scrap yards for old grande puntos to find one.
when my pipe broke i used a longer bit of silicon hose as shot one would kink, it often split it the same place as yours. as it was a lot longer i could just snip the end off each time and re join it.
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 3 Days Ago   #15
More info
Thread Tools
(S) Looking for a aftermarket center pipe and manifold inlet pipe help GPdundeelad Grande Punto 1 27-03-2017 03:33
looking a exhaust down pipe and centre pipe fiat stilo 2.4 abarth. donnie murray (FS) Car Chat 4 22-04-2014 07:41
(T) Pipe to/from Engine damaged - Can someone identify? Matthague Grande Punto 4 04-01-2013 14:58
Exhaust pipe needed (front piece with the lambda pipe) Martin FIAT Boo Archives 2 11-02-2005 14:30
