OK thanks for looking first of all. Anyway the head gasket went on the car the other day i took the head off today (removed deposits with a light brush) replaced all gaskets put it back on and the car won't start everything is back on properly where it came from but i think the timing is out i removed the timing belt tensioner and put it back on as in just bolted it on whilst tightening the belt does this prevent the car starting ?? everything else is fine just wont start if its the timing i am a little unsure how to set it again i did follow a guide from the cinq to remove the head well some parts of the guide. not the bit that tells you about marking the thing before removing my own fault i guess any help would be great.
