Peter Pick-Up and I got a little off topic on a stop-start battery thread so I thought I'd pick it up here.
Last post by Peter was:
Originally Posted by g8rpi
Dual clutch transmissions are an exception as there is no torque converter. You are effectively in gear with both clutches out. However you are still blinding the driver behind you with the brake lights. You still should have the parking brake on though. Just because most people don't do it does not mean they are right.
Rubbish.
In D, during standstill there's always one clutchplate engaged, hence the "creeping" behavior.
Again there is no such thing as a "parking brake", (or maybe the Croma has..??)
It is an emergency brake, that's why Mercedes has a foot operated emergency brake, as a lot of USA cars have this foot operated device as well.
Theory is you can apply more force by foot during an emergency stop when the normal brakesystem fails...
The emergency brake is cable operated by law, so not depending on hydraulics, which can leak..."
Peter obviously has no idea how a DCT works. It's two conventional (not planetary + torque converter like a classic automatic transmission) gearboxes in paralell, both engaged and the dual clutch transfers the engine input to the required one and then changes the other to the next anticipated ratio ready for transfer. If the clutch was engaged when stationary it would be slipping and quickly burn out. When you liftt off the brake at standstill the ECU engages the clutch. Yes I've owned a DCT equipped car (Dodge Journey A.K.A Fiat Freemont) and driven many different automatics including my wife's car.
It is a Parking brake, even in California "Every motor vehicle shall be equipped with a service brake system and every motor vehicle, other than a motorcycle, shall be equipped with a parking brake system." see https://law.justia.com/codes/california/2005/veh/26450-26458.5.html
The Croma handbook calls it a Handbrake (hand operated parking brake)
As do Alfa manuals. The Stelvio is electric and the manual calls it an Electric Parking Brake.
Robert G8RPI.
Rubbish.
Robert G8RPI.
