- Aug 14, 2012
- 6
- 2
Davren - you are an absolute star - if I had a gold medal to pin on you I would.
Thank you so very much.
GF
GF
Hi need a code if you can help. Numbers are:
BP632261751125
7646322316
Thanks![]()
BP632261751125
7646322316
Thanks![]()
Iv'e just noticed that the 10 digit number I gave you is repeated on the top of the unit. However, there is another 10 digit number below this.
The 7646322316 I gave you is a BP Nr. The other Nr is a Fiat Nr 7354362390.
Could this be the issue?
What does the display show before, during and after entering the code?
I am so sorry to have wasted your time, the code is incorrect, because I gave you the wrong last digit. Should be a 6 not 5! It is:
BP632261751126
Sorry again.
Hi Davren.
Just donated.
Need a code for a Punto Cassette player.
Got three numbers on the unit, not sure which you need
Fiat Punto CC 7 642 374316
Prod Nr Fiat 735337935
BP237434017367
Hi
Can anyone tell me the code for a blaupunkt stereo reference number bp137623298017.
Many thanks
For cars with canbus, radio code is also stored in ecu,the code in the head unit and the ecu have to match up for the headunit to fire up.
You can how ever,change the code held in the ecu [dealer] that matches the code for the new head unit.
All the code generaters in the world wont make any radio work on can bus unless the ecu code is the same[ stops the scum nicking your stereo getting a code for it---very easy to get, and selling on]
this is only applicable to can bus system.
Nb. When or if you diconnect you battery, you will not need a code to get your head unit to work, canbus talks to h/unit,talks to ecu,and if they are paired up you h/unit works, this happends evrey time you turn on the ignition
luigi
