The one and only code for fiat radio thread.
Sorry you re right, i made an error.
Part number - 7 647 389 316
The correct serial number
Serial number - 815 BP 738976733449
Hello need help with Blaupunkt code, Ive made a small donation.
BP 7645343316
Fiat 7354180460
Hi krispys, that's a different format than I'm used to (the BP number should be 12 digits), but see if 6646 works.
If that doesn't work, could you please let me know the model number of your radio.
I will try in a bit, here are photos of every number on the radio. If you do mot mind what should the serial start with?
