The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
رجاء مساعدتى فى فك كود تسجيل السيارة فيات
فيورينو
815CM0341E0883071
7640341316
Just in case you missed the announcement, all unlocks are now processed automatically via the forum shop.
You can either just buy an unlock code directly, or make a donation then use coupon code FREEUNLOCK to get your, um, free unlock! :D
I'll keep this thread open to answer any questions or give help - but if you're just posting to request an unlock, then the above link is what you need :)
Hi. Can the forum shop provide a code for our Harman headunit? (don't see it listed). Thanks! (god I hate the electrical in this car.....)
T00BE084473139
Hey, can anyone confirm what brand radio I have , Ive been online and cant get a code for some reason, dont want to pay if its not possible to get the code , can any one help? Fiat Ducato 2019
A2C1075130400011290
S/N 00622
suppllier 96848
date 21/08/2018
thanks
A2C1075130400011290
S/N 00622
suppllier 96848
date 21/08/2018
thanks
That's a Continental
There are two types, but I believe yours is the older one (look for ECE after the model name). You can check if the label is big like this:
Even if yours is the other type, I can swap the order over if needed.
Ive recently bought the code from here and worked great thank you, since i've managed to get the radio working again it keeps cutting out every few munuties and rebooting, Ive tried a firmware upgrade but not fixed the issue, has anyone got a fix for this?
Hi Ben
I have a Giulietta, 2011, I believe it shares a lot of tech (woeful blue and me) hardware with the fiat family still.
Can you supply codes for my head unit?
Tia
If you post a photo of all the labels/serial numbers/model numbers on it, I'll let you know 👍
This head unit, I don't know who's hardware it contains?
