Hi, i need help to get my radio code. I have a Fiat punto Pop from 2014. My radio is a bosch, 815cm0387e1031426
Can you please help?
Thanks in advance!
Thanks in advance!
Yes.... I have the code for your radio.Hi, i need help to get my radio code. I have a Fiat punto Pop from 2014. My radio is a bosch, 815cm0387e1031426
Thanks in advance!
My budget is a little tight right now, I will donate when I get my salary. Is there any chance you can share the code now? Thank you.Yes.... I have the code for your radio.
Click the orange Donate button here: https://www.fiatforum.com/donate
use the anonymous option to donate.
I have the code for your radio.Hi found needed code for 2nd hand Fiat 500 I just bought. Blaupunkt radio, is 7647384316 and Serial number: BP738497048284. Understand need to make a donation. Many thanks.
Thanks for donating to the forum.Hi found needed code for 2nd hand Fiat 500 I just bought. Blaupunkt radio, is 7647384316 and Serial number: BP738497048284. Understand need to make a donation. Many thanks.
Pretty sure codes correct but will recheck and get backHow long it takes for that message to clear will depend on how many incorrect code have been entered, the ignition will need to stay on for the time indicated below
Edit: I just re-read your post, if the code Davren has given is giving the blocked/wait message, then you've likely provided the wrong serial number, double check it and make sure it's correct.
Just checked it again, and 2353 is the correct code for serial number BP738497048284.Tried the code afraid says ‘Radio blocked/wait’. But message not going. Tried turning engine off code request came back but same response. Any ideas?
Thanks in advance
Checked it again and 2353 is the correct code for the serial number you posted. The only thing I can think of, is that the code has been changed within a EPROM inside the radio.So I have photos of serial number and radio and the numbers I gave are both correct.
I don't know of any way to reset the radio. It would need to go to a radio workshop.Thanks for checking again. Anyway of extracting the code or resetting radio? What options do I have really?
