- May 26, 2019
- 3
- 0
Thanks for donating to the forum.
Your code is: 5125
Hello moderator
I can offer any Fiat radio code, so I ask if I can offer my services in this forum to inform the people and I benefit and contribute to enriching the content of the forum.
Hi there.. need a radio code for my 2010 stock bosch head unit.. whats the required donation?
Happy to donate once confirm I've supplied the right numbers
Thanks Joe
Codes:
7 646 386 316
815CM63897182551
There's one digit missing from your serial number. It should be CM followed by 12 digits, not 11.
I have the code for your radio.
Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Use the PayPal button on the left under "Make a donation".... Do not use the button on the right under "Make an anonymous donation"
Ah
815CM638697182551
Thanks..
Hello, Fiat Bravo 2010, Magneti Mareli, instan nav....need master code? Can you generate? I will make donation.
Hi, could anyone supply the code please?
friend you nead to read 24C32 smd
Hi mate,
Sorry for being thick but I don’t know what you mean?
Delphi radios can't be decoded from the serial number. Only way is to read an EPROM chip inside the radio. Alternatively, if it's the original radio fitted to the car when it was produced, you may be able to get the code from a Fiat dealer.
