The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Re: require code for fiat grande punto blaupunkt radio
Hi Daveren,
815bp829882500280
7 648 298 316
I'm doubtful for the "80" marked above, it also seems like 30,36,86. Hope my serial number isn't invalid. The sticker with the serial number has faded & is smudged.
Hi Daveren,
815bp829882500280
7 648 298 316
Thanks for donating to the forum.
The serial number should be stamped into the metal side of the radio.
Your code is:
80 = 3564
30 = 3653
36 = 5146
86 = 3153
Thanks Devran,
Will confirm once i punch it in. I'm also facing another issue. My stereo says "Radio blocked/wait" there is no change at all. i've waited for around 80-90 mins with the key in & the ignition on, but no request for code. The car which i have is a used car, & the previous owner had sold it to me with the radio in blocked condition. Just wanted to know--if the radio is permanently blocked, then does it display something else instead of "radio blocked/wait". Also if i need to wait, then please tell me as to what would be the maximum time. Also what is the process to punch it in? thanks again.
Waiting time depends on how many times an incorrect code has been entered as shown in the table below. If you are guessing at which of the 4 codes I posted is correct, you could be increasing the waiting time. Better to check the serial number stamped into the side of the radio so you know which is the correct code.
You need to leave the radio and ignition switched on until the display shows " CODE " then " - - - - " then enter the code by pressing the appropriate numbered buttons. e.g. If the code is 3564, press button 3, then 5, then 6, then 4. You don't need to press any more buttons to accept the code.
attachment.php
Thanks Davren. Also, does the display message on the radio change from "radio blocked/wait" if it gets permanently blocked? Cuz i've waited for almost 5 hours now, nd still no code request from this thingy. Am guessing for the worst, but hoping for the best.
Hello ,
could anybody help me with the Code for my Blaupunkt MP3 Player.
BP Nr. 7646330316
Fiat Nr. 7354295570
Serial Nr. BP633077798369
My player has only digits from 1 to 6
Thank's in advance!
Re: Radio blocked/wait
Hello, could you please help me retrieve my radio code :(
BP 7646383316
Fiat 7354524840
10x a lot
You have posted the Blaupunkt and Fiat part numbers for the radio, you need to post the serial number. For your radio it will be something like BPX383XXXXXXXX and may be stamped into the side of the radio.
Hello, sorry here it is :
815 BP 638389547751
10x a lot
Hi Davren,
could you please help me with my radio, I cant find the code
serial no: M020215
Model: OB
Fiat part no: 735296997
Visteon part no: 2FCF-18C838-BE
Thank You
Hi Davren,
serial no: M020215
Model: OB
Thank You
Hi, Welcome to the FF.
I can get the code for your radio.
https://www.fiatforum.com/donations.php
