Old 12-02-2006   #1
faster! FASTER!!!
bulldog5046's Avatar
Trader Rating: 2
bulldog5046 has donated!
very strange problems using Aux input
hello, yesterday i received a Sony CDX-F7750S, i made use of the Aux input and finally got my ps2 hooked up
but its making stange hissing noises, and when i drive i can hear the engine revs!
any ideas?
Cheers,
Ryan Edge
Ex Marea Turbo GTi-R owner & BMW Z4 3.0
bulldog5046 is offline Reply With Quote Quote
Old 12-02-2006   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Re: very strange problems using Aux input
well its interferance but i dont know how you would clear it.perhaps one of those suppresors in the HU power cable?
Old 12-02-2006   #3
faster! FASTER!!!
Trader Rating: 2
Quote Originally Posted by custard boy
Old 12-02-2006   #4
custard's Avatar
Trader Rating: 1
mind you if you had a proper console
Old 12-02-2006   #5
faster! FASTER!!!
Trader Rating: 2
i didnt get the noise when it was running strait to the monitor, thinking about it maybe its just a loose cable when i was pulling them all out yesterday? i'll go check
Old 12-02-2006   #6
Doblo Moderator
Ozzie1989's Avatar
Ozzie1989 has donated!
Cool Re: very strange problems using Aux input
Is the hissing there all the time (ie. when playing CDs) or only when your using your PS2. I've also heared that if your using power inverters this can cause problems with such sensitive equipment?
If it's all the time its interfearance somwhere in the wiring to the head unit as has been said, could also be an earthing fault.
Hope you get it fixed
No Longer a Doblo Owner
Ozzie1989 is offline Reply With Quote Quote
Old 13-02-2006   #7
Could it not be noise from the alternator coming through?
Just the when driving you can hear the revs bit know the noise usually increases when its the alt and revs increase.
wozza is offline Reply With Quote Quote
Old 15-02-2006   #8
faster! FASTER!!!
Trader Rating: 2
Quote Originally Posted by wozza
yeah thats how it sounds and its only when using the PS2/LCD/AUX input fine on CDs and radio...well radio is okay aslong as the ps2 and lcd are off lol
Old 01-03-2006   #9
Formerly mog1571
Luke M's Avatar
Trader Rating: 2
Luke M has donated!
check your phono cables. i once got the phono cable trapped under the rear seats and cut the outer insulation so the shielding was connecting with the metal of the seats. i had buzzing for weeks until i moved around all the wiring and discovered the cut.
Luke M is offline Reply With Quote Quote
(T) AUX input on Connect Nav+ JohnsonChris Stilo 23 21-09-2009 10:07
Sat Nav Aux input help!!! fieldy I.C.E 0 05-02-2005 21:37
aux input on sony head unit? arc I.C.E 11 13-07-2004 02:50
(T) strange starting problems jamie123 Punto (Mk2/2b) 2 24-01-2004 00:12
