very strange problems using Aux input
bulldog5046
faster! FASTER!!!
hello, yesterday i received a Sony CDX-F7750S, i made use of the Aux input and finally got my ps2 hooked up (y)
but its making stange hissing noises, and when i drive i can hear the engine revs!
any ideas?
Cheers,
Ryan Edge
custard
Status: DEFCON Grumpy
Edinburgh
well its interferance but i dont know how you would clear it.perhaps one of those suppresors in the HU power cable?
OP
OP
bulldog5046
bulldog5046
faster! FASTER!!!
:confused:
OP
OP
bulldog5046
bulldog5046
faster! FASTER!!!
custard boy said:
mind you if you had a proper console ;)
i didnt get the noise when it was running strait to the monitor, thinking about it maybe its just a loose cable when i was pulling them all out yesterday? i'll go check
Ozzie1989
Doblo Moderator
South Wales
Is the hissing there all the time (ie. when playing CDs) or only when your using your PS2. I've also heared that if your using power inverters this can cause problems with such sensitive equipment?
If it's all the time its interfearance somwhere in the wiring to the head unit as has been said, could also be an earthing fault.
Hope you get it fixed :)
wozza
Manchester
Could it not be noise from the alternator coming through?
Just the when driving you can hear the revs bit know the noise usually increases when its the alt and revs increase.
OP
OP
bulldog5046
bulldog5046
faster! FASTER!!!
yeah thats how it sounds and its only when using the PS2/LCD/AUX input fine on CDs and radio...well radio is okay aslong as the ps2 and lcd are off lol
Luke M
Formerly mog1571
widnes, liverpool
check your phono cables. i once got the phono cable trapped under the rear seats and cut the outer insulation so the shielding was connecting with the metal of the seats. i had buzzing for weeks until i moved around all the wiring and discovered the cut.
