I'm pretty sure, that won't make any difference, it should still boot up, sub out is yellow molex connector on the back of your h/unit,in fact you can connect an amp to this as well as it is a pre out.
Have you the code for the h/unit?
If yes, this code needs inputting into the ecu--main dealer only.
Luigi
