hello
i recently bought a five door 2000 fiat punto, and just set about upgrading the head unit and door speakers. i fitted the new headunit, a Sony CDX-GT44IP and ran it on the factory speakers with no problem for a few days.
i then installed a pair of JBL GTO-6537, which worked at first. now however, whenever i turn the headunit on, a horrible high pitched squeal type noise comes pretty loudly from the door speakers, and the headunit reads 'failure'.
i decided i must have done something wrong, so firstly tested the speakers with the old headunit, same problem. i then took the door speakers out and did nothing more than take the wires off, then push them back on. after doing so, everything worked again.
now i just jumped in the car, turned the headunit on and everything was still working. so i shut the drivers side door, and once again the high pitched noise came back the moment the door closed. whats confusing is that the issue can be fixed temporaily. even when it was working though, i could hardly put the volume above 20 without getting a popping/cracking noise from the speakers.
any help would be fantastic!
