Tools and Consumables
A quick summary of the things you will need to do the job are detailed below.
- Screwdrivers / Spanners
- Utility Knife / Hacksaw
- Pliers
- Jubilee Clips (~30mm Diameter)
- PTFE/Teflon Tape
- Distilled Water (2 Litres)
- Engine Coolant (2 Litres)
- Temperature Gauge (and sender if not included)
- Cable
- Coolant Hose Adapter (30mm OD)
- Jack / Axel Stands
- Multimeter
They look like:
If you would like to completely flush the cooling system while you are at it, seeing as you will be doing half anyway, them you will also need:
- Paper Gasket (or specific thermostat gasket)
- Gasket Sealant
