Here is a list of the PIDs available for the Dual EGR non adblue Euro 6 X290.
ECU Marrelli 9DF CF6/EOBD
The templates I use for Multiecuscan are given on subsequent pages
MES Pids
1​
AC compressor relay​
2​
AC pressure sensor​
3​
AC request​
4​
AC system present​
5​
Accelarator present​
6​
Actual turbo control position​
7​
Air qty control HPEGR​
8​
Air qty control LPEGR​
9​
Air temp boost/manifold​
10​
air temp MAF​
11​
Air temp signal boost​
12​
Atmospheric pressure​
13​
AVERAGE DISTANCE BETWEEN LAST REGENERATIONS​
14​
AVERAGE DURATION OF LAST REGENERATIONS​
15​
AVERAGE TEMPERATURE OF LAST REGENERATIONS​
16​
Battery voltage​
17​
Boost pressure​
18​
Boost pressure signal​
19​
Brake booster vacuum switch​
20​
BRAKE CONTACT 2​
21​
Brake node NFR​
22​
Brake pedal status​
23​
CLUCH CONTACT 2​
24​
CLUTCH PEDAL LEARNING​
25​
CLUTCH PEDAL POSITION​
26​
Cruise control +​
27​
Cruise control -​
28​
Cruise control error​
29​
Cruise control RES​
30​
Desired boost​
31​
Desired fuel pressure​
32​
Desired fuel qty​
33​
Desired intake air qty​
34​
Desired turbo control​
35​
DIFFERENTIAL SENSOR PRESSURE​
36​
DIFFERENTIAL SENSOR PRESSURE signal​
37​
DISTANCE from last DPF regeneration​
38​
DISTANCE from last DPF replacement​
39​
DISTANCE NEXT 'OIL CHANGE'​
40​
Distance TRAVELLED WITH DPF WARNING LAMP ON​
41​
EGR EXCHANGER exclusionVALVE​
42​
Engine ECU​
43​
Engine over rev count​
44​
Engine start up
45​
Engine temperature
46​
Engine temperature light
47​
Engine temperature signal
48​
Failure indicator light
49​
Fan 1st Speed
50​
Fan 2nd Speed
51​
Fan Speed
52​
Forced Regeneration state
52​
Fuel consumption​
53​
Fuel filter heater relay​
54​
Fuel pressure​
55​
Fuel pressure signal​
56​
Fuel temperature​
57​
Fuel temperature signal​
58​
FUEL PUMP RELAY CONTROL​
59​
Gas pedal position​
60​
Gas pedal position track1​
61​
Gas pedal position track2​
62​
Gear engaged​
63​
Glow plugs indicator​
64​
HPEGR actual​
65​
HPEGRcontrol​
66​
HPEGR position control​
67​
HPEGR target​
68​
HPEGR valve learn​
69​
HPEGR valve opening​
70​
inj correction cyl 1​
71​
inj correction cyl 2​
72​
inj correction cyl 3​
73​
inj correction cyl 4​
74​
injection advance​
75​
injection advance​
76​
injection advance​
77​
injection advance​
78​
injection fuel qty​
79​
injection fuel qty​
80​
injection fuel qty​
81​
injection fuel qty​
82​
injection fuel qty​
83​
injection time​
84​
injection time​
85​
injection time​
86​
injection time​
87​
injection time​
88​
inj code cyl 1​
89​
inj code cyl 2​
90​
inj code cyl 3​
91​
inj code cyl 4​
92​
injector voltage​
93​
Intake air qty​
94​
Lambda Oxygen​
95​
Lambda Oxygen​
96​
Lambda sensor signal​
97​
Lambda temp​
98​
LPEGR actual​
99​
LPEGRcontrol​
100​
LPEGR position control​
101​
LPEGR target​
102​
LPEGR temperature​
103​
LPEGR valve learn​
104​
LPEGR valve opening​
105​
MAX Engine speed​
106​
MAX Engine over rev​
107​
Number of programmings​
108​
Number of Regens​
109​
Number of Regens INTERRUPTED BY KEY-OFF​
110​
Number of Regens SINCE LAST OIL CHANGE​
111​
Odometer​
112​
Odometer at last Oil change​
113​
Odometer at last overrev​
114​
Odometer at last programming​
115​
Odometer​
116​
Oil change counter​
117​
Oil degradation​
118​
Oil pressure​
119​
Particle filter status​
120​
Particle filter temp​
121​
Particulate filter clogging​
122​
Pre-cat temp​
123​
Preheating control unit feedback​
124​
Preheating unit command​
125​
Pressure regulator openning​
126​
Regeneation process​
127​
Speed limit​
128​
Speed limit from Proxi​
129​
STOP&START FUNCTION​
130​
STOP&START FUNCTION request​
131​
STOP&START temporary deactivation status​
132​
Target cruise speed​
133​
Temperature after particle filter​
134​
Throttle position​
135​
Throttle position target​
136​
Throttle valve openning​
137​
Total fuel qty​
138​
Total number of regens​
139​
Turbo actuator command​
140​
Unversal code​
141​
Vehicle speed​
142​
Vehicle version​
143​
Water in fuel filter​
Qty​
Example Template used
5
Injectors EGR General​
7
General​
2
Injectors​
8
Others​
9
DPF Static​
4
Regen system​
Next page: Alfaobd PIDs
