Wiring
You can now screw the plastic holder and LED back into the headlight unit.
Now you have a choice, you can wire them up to come on with the sidelights, or you can have them on as Day Running Lights.
On with sidelights;
On the sidelight find its wires, both are black, using scotch clips place 1 on each of the black wires, then place 1 wire from the LED in each.
Squeeze the clip in place, and close over the lock, turn on the sidelights and they will come on with them.
On as Day Running Lights;
You will wire them up to an igintion switched +, so as soon as the key is turned, the LED's will be on.
You can splice into the cig lighter, and run your cable back out through the firewall, neatly down along the inner wing to the drivers headlight, then loop it through over to the passenger side.
Place the other wire from the LED on an earthed point, (where you have screwed the plastic part back on)
When key is turned on, LED's will be on constantly.
If you dont want to use scotch clips, you can splice into the wires, add a heatshrink sleeve and solder in your extra wire, then seal it up with sleeve.
You should end up with something like this...
There is no beam, so they shouldnt dazzle other drivers
