Fitting the brace & adjusting it.
Once you have tapped the holes out with the bolts, fit the brace in place. Again apply copious amounts of copper grease as this will help with anticorrosion & also help the bolts do up. Do the bolts up, probably best to do them up a little at a time one at a time. With a 24mm spanner undo the adjusting nuts on the strut brace & with the 17mm spanner adjust the centre nut so that it pulls the ends of the brace inwards. Do the 24mm nuts up & it will be locked in place.
