Stripping down to gain access
2pence coin / Large screwdriver
Undo the 2 plastic lugs that holds the fuse box cover in place and unhinge it
Then using a suitable allen key - Mine were 2.5mms
Undo the 2x top cowling bolts
and then the 2x Cowling bolts hidden under the adjustment lever for the coloumn
Now getting the bottom part is a fiddle, it needs to be disconnected from the internal lugs
and fight it past adjustment arm as well
Patience and gentle movement it comes off
3x 10mm or 13mm bolts
To remove the plate covering up the ECU
Exposing the Steering Coloumns magic pixie dust control unit
Disconnect the wires going to the ECU - Ensure your ignition is off, to prevent errors been generated
With a bare bumed ECU, look down the side, near the Internal earthing point, you will see a tiny screw - Euro screw
I used needle nose pliers and slowly worked it off
I struggled to get my 1/4 inch ratchet in to remove it, so a euro socket may be just as bad
The screw doesn't actually thread in the ECU, its just sits in a plastic lug
Now you should be left with a bunch of wires and 1 coloumn shaft ready to remove
Next page: The Removal of the shaft
Previous page: The Tooling needed
