The usual applies here, this is the process i went through removing and refitting the shaft
I personally take no responsibility to any damage to you - the property around you etc etc
The steering system is crucial to driving, should anything fail and you have an accident because you failed to install it correctly - i will not be responsible, your own work is your own work
Ensure all fixing are refitted correctly and suitable tightened or torqued up
I advise you read my process from start to finish to gain an understand who/where/what/why/when etc
With that bit out the way - LETS BEGIN!
The Tooling needed
1x Brick
1x 2pence coin / Large blade screwdriver
Allen Key Set
1 Pry bar - reasonable length
Socket Set + Suitable Ratchet
Possibly Socket extensions
Long needle Nose pliers **
Stripping down to gain access
2pence coin / Large screwdriver
Undo the 2 plastic lugs that holds the fuse box cover in place and unhinge it
Then using a suitable allen key - Mine were 2.5mms
Undo the 2x top cowling bolts
and then the 2x Cowling bolts hidden under the adjustment lever for the coloumn
Now getting the bottom part is a fiddle, it needs to be disconnected from the internal lugs
and fight it past adjustment arm as well
Patience and gentle movement it comes off
3x 10mm or 13mm bolts
To remove the plate covering up the ECU
Exposing the Steering Coloumns magic pixie dust control unit
Disconnect the wires going to the ECU - Ensure your ignition is off, to prevent errors been generated
With a bare bumed ECU, look down the side, near the Internal earthing point, you will see a tiny screw - Euro screw
I used needle nose pliers and slowly worked it off
I struggled to get my 1/4 inch ratchet in to remove it, so a euro socket may be just as bad
The screw doesn't actually thread in the ECU, its just sits in a plastic lug
Now you should be left with a bunch of wires and 1 coloumn shaft ready to remove
The Removal of the shaft
Nearly there i promise!
Time to free the shaft,
There is a 13mm bolt or nut and bolt combo holding the shaft in place onto the steering rack
Make a note of where the wheel is sitting, how the steering wheel is sitting and how the as you will be moving parts and knocking them out of alignment
Then using your brick and leverage assistant, disconnect the lower section
remove the Upper bolt - i cant highlight it - paint doesn't like my photo's
but it was a 10mm IIRC, look up where the EC
You may need to turn the wheel to access the bolt, make sure you note rotation and degree of turn
For me - i had to turn 90deg's approx
Now using the pry bar again, just assist the upper knuckle free!
Wiggle it out - and hey presto!
Now its important to make sure you have the correct part, i spent 20mins in scrappy pulling what i through was the correct part.... how wrong was i....
Refitting
I love this section
Its the reverse of the removal
Making sure you align your steering back up, you dont want to be driving with 90deg steering for no reason
I found attaching the top bracket first easier, as it was weight supported for aligning the bottom splines up
Top is a square peg, the bottom is splined
Why replace?
i would say 99% probably will NEVER follow this guide, its a part that will most likely way outlive the vehicle
There is a recall notice out for certain Punto's to have the coloumn shaft changed due to a batch or poorly manufactured ones been present, but never seen a "bad one yet" till i met mine
When i next get chance - i will print the information off and post a like in the comments box!
reason i was changing as for some reason my bottom knuckle had developed play making a loud clunking noise
When the shaft was in my hand there was 1 thou play, but it didn't half make a racket when power steering smacked it for me
Due to the nature of power steering, that 1thou play related to about 5mm play in the wheel
Driving down rough roads, the steering wheel would be clunking like hell while going straight, Its fine to drive, as mine was only an MOT advisory, but i like my cars to be the best they can!
Ziggy
