Okay, first thing's first, having a stuck latch on your glovebox is possibly the most annoying thing in the world.
By me saying "stuck" I mean, when you open the glovebox, the latch becomes lodged deep within the glovebox, and so therefore will not shut.
I had decided to skive college today, so I thought I would take a crack on fixing this.
(Mk2 1.2 60 Active by the way, in case this doesn't work for other models, but I don't see why it shouldn't)
First off, you will require:
1. Using a fine blade, run the blade along the gap outlined:
Push the blade in far enough so that it splits the adhesive between the two parts of the door, all the way round.
2. Again using a fine blade, separate the cover of the latch (what is closest to you) and the sides of the glovebox as marked:
3. Once the sides have been disconnected from the door, remove the cover of the latch (again using a fine blade) outlined:
4. Now the latch mechanism should be visible:
Sand down both sides of the grey latch that are marked:
Sand them down to a equal level, until when the handle of the door is pulled and released, it should move correctly back and forth within its casing.
- A fine blade (kitchen knife, stanley knife etc.)
- Sand paper
- Cotton buds
- Strong plastic adhesive
MAKE SURE THERE IS NO SANDING EXCESS UPON THE LATCH, AS THIS COULD CAUSE THE LATCH TO BECOME STUCK AGAIN. I FOUND THAT COTTON BUDS ARE EXCELLENT FOR REMOVING THIS
5. Once you are happy with the job, using a strong plastic adhesive, glue it all back together, using the raised lines all along the parts of the glovebox.
CREDIT TO LAROC FOR INSPIRING ME TO CREATE THIS GUIDE:
https://www.fiatforum.com/punto/221363-punto-glove-box.html
