It was all going so well!
One little problem . . .
Retrofitting cruise control to the Stilo incurs one problem; the LED on the instrument cluster will NEVER illuminate. From what I understand, the cruise control stalk is wired straight to the Engine Node (hence it is not placed on the CAN line at the clock spring). When switched ON, the engine node will place a “Cruise Control is ON” message on the CAN network. What would normally happen is the Body Computer would read this, then place a “Switch Cruise LED ON” signal on the CAN, for the instrument cluster to pick up. However, as none of the Stilos without it haven’t had the option programmed into the Body Computer, it will not know what the “Cruise Control ON” signal is, hence never submitting the “Switch Cruise LED ON” signal. This you’re going to have to accept and live with! The Examiner can switch the light on manually by mimicking the “Switch Cruise LED ON” signal though.
Next page: Are you wired up?
Previous page: Questions? Comments?
