Old 20-01-2007   #1
Steering wheel noise and other things...
1. When the car is stationery and I turn the steering wheel from side to side, it makes a clicking sort of noise. If I turn, it really slowly and press down on it very very slightly, it makes a sort of a creaking noise. What could this be?
2. When I drive very slowly over cobbles, for example, or an uneven road, there is a very slight knocking noise - could this be the steering rack?. Could this problem be related to problem detailed above?
3. Sometimes when I turn left round a corner, particularly over a speed hump outside my house, there is a sort of creaking/knocking noise from the left side of the car, I can't determine if its from the front, middle or back. Could this just be tension as the car is turning?
Other than that, I love it...!
Thanks.
jb1970 is offline Reply With Quote Quote
Old 20-01-2007   #2
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Re: Steering wheel noise and other things...
Quote Originally Posted by jb1970 View Post
Thanks.
Pretty sure 1&2 is steering rack. For 3 I also got a creak in my sporting when going over a steep bump or cornering fast ended up being a loose bit of trim I think either way didn't take long to fix .
ChrisUK is offline Reply With Quote Quote
Old 20-01-2007   #3
1&2 is the same as i have on the wifes, and its booked in with tha garage this weds for an inspection, i will tell you how i get on, ps someone else on here had the same and his needed a new steering rack
pps how old is yours ?
http://i2.photobucket.com/albums/y8/182_blue/182.jpg
182_blue is offline Reply With Quote Quote
Old 20-01-2007   #4
SNAP!
luvduvs's Avatar
luvduvs has donated!
Australia
I have issue [1] (but not [2] or [3]) as well and the dealer said it was a loose nut/bolt somewhere in the steering (didn't say exactly where though). When I collected my car a few weeks ago it was apparently fixed, but no, it still makes that clicking noise. I'm not so sure if I have that much faith in my dealer anymore....
luvduvs is offline Reply With Quote Quote
Old 21-01-2007   #5
Quote Originally Posted by 182_blue View Post
Mine is an 06 plate (registered March 06).
Old 21-01-2007   #6
sounds like the steering rack
Old 23-01-2007   #7
i had a similar problem to number 3 which turned out to be a loose wheel arch trim on the passenger side front wheel that was catching on the wheel when turning left and worst when reversing
washinpowder is offline Reply With Quote Quote
