Old 24-11-2006   #1
Question towing a caravan with the 1.3 90
Hi All, i am thinking of towing a small caravan ( max weight 900kg) with a gp dynamic 1.3 90 mj. i have not got the gp yet as my concern is that some forum members give the impression that its pulling power is naff due to the turbo lag. has anyone any experience of towing with this vehicle and why is there no turbo lag on the active mj 75?? regards Lou
Loury777 is offline Reply With Quote Quote
Old 24-11-2006   #2
Re: towing a caravan with the 1.3 90
Quote Originally Posted by Loury777
I think that it would be a nightmare, the engine is good at making horsepower and not torque and the turbo lag is a real problem.
maharg null is offline Reply With Quote Quote
Old 24-11-2006   #3
Hill starts would be a particular nightmare cos of the amount of revs you would need to get it off the line.
Problem is then all the torque and power will kick in so you could prob wave bye bye to the clutch quite quickly too!
AllSaintChris is offline Reply With Quote Quote
Old 24-11-2006   #4
popping out
dan-the-man has donated!
as long as you keep the turbo spinning it should be ok, but as chris said you'll wear the clutch out quicker.
dan-the-man is offline Reply With Quote Quote
Old 24-11-2006   #5
RIP L181 VBB
AppleSei's Avatar
Trader Rating: 4
AppleSei has donated!
Cricket Craziness Champion
Check towing weights and kerb weights of both car in your manual and check against the caravans weight
I personally wouldnt tow a caravan with a 1.3 based on personal experience.
A folding camper and a trailer tent you might get away with, but i agree with sentiments above regarding a caravan
2001 Modded Sei Sporting - GONE!!
MY ACCIDENT THREAD - BE CAREFUL OUT THERE! - http://www.fiatforum.com/leisure-lou...cky-alive.html
AppleSei is offline Reply With Quote Quote
Old 24-11-2006   #6
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
There is no turbo lag on the MJ 75 as there is no turbo its a belt driven supercharger!.
Personally I dont think you will have much problem its quite a torquey engine and Ive seen people tow similar weight on a 1.2 16v corsa although they did struggle .
ChrisUK is offline Reply With Quote Quote
Old 24-11-2006   #7
Trader Rating: 10
dave has donated!
no sell the caravan
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 24-11-2006   #8
The Negotiator has donated!
Sounds like a very bad idea, what does the car manual say for it?
Now drives: BMW 635d (wow!)
Past:
Renault Laguna Coupe GT 180. Laguna Initiale dci. 52 Megane 1.9dCi, Y-reg Fiat Brava JTD (Pale Blue) (2006), '51 Fiat Brava 80 SX (black) (2006), M-reg UNO (2003-2004)
The Negotiator is offline Reply With Quote Quote
Old 24-11-2006   #9
Moderator
Andy Monty's Avatar
Andy Monty has donated!
I have a 1.2 petrol active and it pulls a conway trailer tent (challenger) ok it even kept pulling away on the motorway bridge over the Ouse on the M62 between Howden and Goole (my old 1.1 fiesta used to struggle solo) but i wouldnt like to pull anything bigger..
Just think its lighter and has less drag you shouldnt pull any caravan with a mass of more than 85% the kurb weight of the car in any circumstance as the car wont be able to control it if it starts to snake for example and a heavy van might invalidate your warenty...
Old 24-11-2006   #10
Trader Rating: 10
dave has donated!
shouldnt pull any caravan ever, bloody meanace they are
Old 24-11-2006   #11
My parent's one is going for its service tomorrow so will be sat in a scenic towing one, how embarrassing They are much more exciting though that they used to be, they have to beep when you indicate
Past:
Old 25-11-2006   #12
Moderator
Andy Monty's Avatar
" are much more exciting though that they used to be, they have to beep when you indicate"
unless you find the relay and cut the cable to the buzzer or pack with foam rubber (i dismantled mine and stuffed an foam ear plug in the case over the buzzer element peace has now returned.. or fit a light in the dash
Yes i know its a legal requirement...
Old 25-11-2006   #13
Trader Rating: 10
dave has donated!
why do they have to beep when you indicate?
i think they should make them beep all the time, that might stop you buggers having them
sort of on topic, has the law changed re towing them big twin axle things? you used to need a commercial vehicle to pull any thing bigger than the smallest hobby, but now i see loads being towed with 4x4s and people carriers, even see a few being towed with a normal car
Old 25-11-2006   #14
x Alex x has donated!
my mate 1.0 3cyl corsa pulls 3 bikes and a big trailer so i think youll manage
Grande Punto 1.9 Multijet Sporting
x Alex x is offline Reply With Quote Quote
Old 25-11-2006   #15
Many thanks for everyones input with the exception of cynic dave, the caravan in question is a lightweight Sterkeman 370 loaded will only be 850kg the gp active kerbweight at 1105kg with a max towing weight of 1000kg it will not be a problem. you all have answered my question regarding the turbo lag thanks for that, by the way i have towed this same caravan with a PANDA mj with no problems whatsoever with an average 33 mpg. i now have a gp 75 not yet towed with it. Reason i put my question in the first place was that i have the option to change it for a dynamic gp. i have taken your opinions on board and will stick with the Active mj 75 many thanks everybody. a special thanks to Chrisuk as i had no idea regarding the supercharger. Lou
(T) 1.3 multijet vs 1.3 cdti service interval hendrik4dnet Doblo 6 21-11-2006 18:09
(G) 1.2 dualogic vs 1.3 multijet? hendrik4dnet Panda 7 28-08-2006 18:03
(T) How to mount a towing hook? fredand44 Punto (Mk2/2b) 0 28-06-2006 11:16
Small Car Towing a Caravan Seicento Racer Leisure Lounge 12 16-11-2005 22:23
