Superboy
Member
So today I press the button to take the drivers window down a bit and the motor kicks in but sends the window up....there's a "jolting" sound when it does this as though it's ever so slightly reversing and then powering the window up. It kept doing this about 3 times.
I turned the car off and left it 5 seconds and push the button down again and this time the window lowers but the "express down" feature is disabled and the window stops when I release my finger.
Turned the ignition off, waited and then turned back on again and the window worked fine.
Is this a common problem? and is there a way of "resetting" it myself.
I know in the handbook it says to power the window all the way down then power it up and when it stops to keep your finger on the "up" button for a further 2 seconds.
If anyone has experienced this problem I would appreciate their comments.
