the missing plate on some grande puntos is actualy a very small metal plate about 2" by 2" all it dose is stop your knee diging into the ignition lock as it has a raver pointy edge pointing towards you
ima if you have crashed so servealy that the rack and subsequenly the colom and ignition lock is heading you way then your knees are the least of your wories
at 40 mph this plate makes no diference to the way you are protected and therefore it is still a 5 star car most of the afected cars were amended at bristol and only a few were sold with the missing plate
as for the reasone it was left out it was not simply forgoten as we all know nothing stops production
as for time fitting the part ten minuites if that so you can wait wilst it's done it shouldent inconvienience you much
between you and the lock their is the outer plastic trim then a iner plastic guard bolted to the colom backed with foam and then the plate is riveted to the inside of that inline with the ignition lock so even without this part their is still plenty beetween you and the lock
the part that is replaced is just the hole iner guard a new one is fited with the plate atached
i hope this finally puts this subject to rest
