Old 14-07-2006   #16
Re: Faults to date
Quote Originally Posted by allanhelen
One general question If you use the key to open the door on the pasesnger side should it open all the doors?
No.
Gavin
gavin is offline Reply With Quote Quote
Old 14-07-2006   #17
Re: Faults to date
Quote Originally Posted by T14086
What kinda of fuel consumption are you getting Bogman out of interest?
Depends, I live in a fairly hilly area and in out to the city often, average 50mpg driving it harder than the Mazda, in any level open ground it averages 10-15mpg more again, quicker than the 1340cc Mazda and that was averaging 35/36 to the gallon
Bogman is offline Reply With Quote Quote
Old 14-07-2006   #18
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Faults to date
Thats not bad at all.
hmmmmm if I could only convience the wife!
Old 14-07-2006   #19
Scandinavian Passion....
StoneNewt's Avatar
StoneNewt has donated!
Re: Faults to date
V70 faults to date, all fixed -
1) Front near side suspension mounts fowling smooth operation of suspension & breaking systems (required specialist machining of mounts! )
2) Rear seat back locked at about -30 from vertical
3) Front passenger air bag kept on sending phantom deployed signals when braking hard (this causes an emergency fuel cut)
4) warped/mis-shapen spare wheel
5) During modification it was noted there was a bolt missing on the engine side of the exhaust manifold (tuners fixed free of charge)
6) It wasn't quick enough
Seicento Sporting, 1.1 8v N/A, Dark grey
Seicento Sporting, 1.2 8v turbo, Yellow
Volvo V70 D5 Sport, 2.4 20v twin-turbo, Black
StoneNewt is offline Reply With Quote Quote
Old 15-07-2006   #20
x Alex x has donated!
Re: Faults to date
does on my mk2b
Grande Punto 1.9 Multijet Sporting
x Alex x is offline Reply With Quote Quote
Old 15-07-2006   #21
Trader Rating: 1
ELTSBABY has donated!
Re: Faults to date
I dont own a Grande Punto but have herd there is a fault with the radiator fans motors not swiching on and off propley when engines over temp
ELTSBABY is offline Reply With Quote Quote
Old 15-07-2006   #22
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Faults to date
Where did you hear this from? because Fiat have no reported cases of this.
Old 15-07-2006   #23
Netherlands
Re: Faults to date
Quote Originally Posted by ELTSBABY
That is the first time I hear that and if it's on all GP's there would be a lot of GP's broken right now. Mine works.
http://www.xs4all.nl/~bvdam/temp/teddysig.png
Quote Quote:
Originally Posted by AlexGP
I find myself putting my head in the lap of my passenger
I WANT A SHUFFLE/MIX BUTTON FIAT!! http://www.mobileread.com/forums/ima...1/furious3.gif
diablo_NL is offline Reply With Quote Quote
Old 15-07-2006   #24
Trader Rating: 1
Re: Faults to date
Been taking to a few Fiat machanics who work in the same dealership they have had up to 23 new grande puntos with same fault sorry didnt ask which model but i would get yours checked out
Old 15-07-2006   #25
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Re: Faults to date
Yep mines fine stays normal temp (half way) even in hard driving with 26 Degrees C ambient temp.
ChrisUK is offline Reply With Quote Quote
Old 15-07-2006   #26
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Faults to date
Like I said (and I just checked again just now) there has been no reported cases.
Fan operation is checked (twice) at PDI stage anyway.
Old 15-07-2006   #27
Trader Rating: 1
Re: Faults to date
Like i SAID you just don`t know what happens behind closed garage doors never mind what the computer says
Old 15-07-2006   #28
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Faults to date
Well I work behind those closed doors & I have never heard of this fault,either from personal experience,from other technicians,from technical seminars,from Fiat field engineers or from Fiat technical department!
Old 15-07-2006   #29
Netherlands
Re: Faults to date
Amen!
Quote Quote:
Old 15-07-2006   #30
Trader Rating: 1
Re: Faults to date
You mean you havent had your head under the bonnet and your hands dirty you just fill out paper work in a fiat garage Time will tell just thought should tell whats happend up our fiat main dealer
(G) Instruments faults, not the usual ones lowline Marea 2 30-03-2006 22:08
(T) switched off and still giving faults Sandro JTD Stilo 8 14-02-2006 14:31
(T) Time and date problem Koa Stilo 3 14-11-2005 13:16
(G) Still no delivery date for factory order!!!! AndyJab Stilo 11 05-03-2004 01:40
(T) Brava 80 (1242 16v) Formula - faults to date RobW Bravo / Brava 4 20-01-2004 04:48
