FIAT Auto Specialist Team
Old 3 Days Ago   #1
Netherlands
Punto doesn't go into gear
Dear reader, I bought a semi-automatic Fiat Punto a while ago, and after a few miles the problems started; The car went into neutral while driving and a warning light came on with: ''have gearbox checked, check manual'' and then the car went into reverse / gear very hard. What could be wrong, and is it possible to fix it?
And is it still worth keeping this Punto alive?
Fauxhole is offline Reply With Quote Quote
Old 3 Days Ago   #2
varesecrazy has donated!
Re: Punto doesn't go into gear
Hi
Is the fluid tank still showing it level?
Are the Brake lights showing correctly??
The car is worth investigating..
But NOT worth hours of Workshop time
Old 2 Days Ago   #3
Netherlands
Thx for the response. I think there’s a leak in the transmission robot.. seems like it Doesnt make enough pressure.
Old 2 Days Ago   #4
Quote Originally Posted by Fauxhole View Post
Does the pump still run as the door opens?
Old 2 Days Ago   #5
Netherlands
Yes the you can still hear the pump when opening the door!
Old 2 Days Ago   #6
Netherlands
Quote Originally Posted by varesecrazy View Post
The pump still runs when i open the door. Would that make things easier, or worse..?
Old 2 Days Ago   #7
Thats sort of good news
The pump and its switches obviously work.
But you shouldnt have that fluid leak
Look in the Grande Punto section for info
Old 2 Days Ago   #8
Netherlands
Great . i went to the garage the other day, and they told me that the whole transmission robot has to be replaced which is 1700 euro's without TAX.. They've found oil behind a plate. I'm not sure if it's the right translation, but he called it a triangle plate.
thx for the response!
Old 1 Day Ago   #9
Netherlands
Today I sat in my car to see what exactly is wrong. After checking everything, I walked out of the car and found out that I had forgotten to close my window. I then put my car on the ignition, and did not start the engine.
But it turns out, on contact it just switches well, and it also goes into its R without it shooting out. I'm not a car expert so I really have no idea if that's always the case, but this seems strange to me. Anyone any idea?
(T) Cinquecento doesn't like changing gear.... marktoby2449 Cinquecento / Seicento 5 3 Weeks Ago 22:28
(T) punto jtd mk2 car doesn't move in gear dubsential Punto (Mk2/2b) 3 28-07-2021 17:04
(T) Trusty Fiat Punto can select gear but doesn't move at all SHoops Punto (Mk2/2b) 4 25-03-2020 18:14
(G) Replacement gear knob doesn't fit vivienz Panda 0 20-05-2018 12:41
(T) Gear Stick 'lumpy' and doesn't self-centre Stub Mandrel Stilo 3 24-06-2017 08:27
