Technical Rear fuse box location?
Falkirk
Anyone know the location of the fusebox on a 2006 Grande Punto?
The manual indicates that it is in the boot on the left hand side behind the lining- However, only thing I can find there is a control/electrical assembly box for the towbar wiring.
Here is a pic of mine, hidden under the carpet:
Does it look the same, what fuse are you looking for?
OK so I should state that I am looking for the rear fuse box. I can find the one next to the battery as well as the one by the drivers knee (left hand drive). It is the rear one I am looking for ..
And I am looking for the fuses for the passenger window (right) and seat heating (left).
Someone has posted a picture for you above of the rear fuse box!?
It is in the boot on the left hand side (if looking in the boot from behind the car) and is behind the carpet trim down the side of the boot behind the rear wheel well
Not all cars have it so If you can’t find it in that location then it’s not there, your car doesn’t have it
Well the fuse box might not be there but the above mentioned fuses must be somewhere ..
The two pictures does indeed show a fuse box but it is kind of difficult to see the location relative to anything distinguishing.
Right of pic - rear of left wheel arch
Left of pic.. rear of car body.. tail light is above this
Hope that helps :)
