- Dec 23, 2019
- 47
- 61
everson38
Sorry to hear you did not do a battery check at a local shop.
This will help in deducing a bad battery.
You drained the battery so much that it ended in all kinds of failures and error messages.
This can also damage the battery even more.
My suggestion:
charge battery overnight, drive to a shop where you can test the battery.
CCA measure and internal resistance will give an idea of battery condition.
If all looks sufficient then testing and measuring under load will be the next steps to find possible bad earth connections or alternator failure.
My suggestion:
