Closed Thread
Thread Tools
Old 24-08-2018   #1
Finland
Guide: Renewing a gear shifter seal
My Grande Punto 2008 1,2 gear box looked like this:
I thought that drive shaft seal was leaking but I was advised it probably was a gear shift seal leak. It actually was the case and it looked like this:
I ordered a new seal from eBay (30 ). Replacing an old seal took about three hours work and it were pretty simple job. Only tools needed were 10 mm spanner, 13 mm socket, two flat screw drivers, a punch, a hammer and sealant glue.
Take battery terminals off (10 mm spanner).
Remove battery (13 mm socket),
Remove the battery tray (13 mm socket):
Remove clutch slave cylinder (13 mm socket):
Open ground gable nut (13 mm socket) and remove reverse light switch connector:
Gear cables can be removed with one or two screwdrivers:
Gear shifter is attached with five screws (13 mm socket):
Gear shifter removed:
Remove lock pin with a punch:
Remove a seeger ring with a screw driver:
Gear shifter disassembled:
Remove old seal carefully with a screw driver and tap a new seal in place:
Assembly in reverse order. Use sealant when attaching gear shifter to gear box:
Renew gear oil.
Hope somebody find this instruction useful.
Thanks Bernievarian thanked for this post
Likes Bernievarian liked this post
Jarmot is offline
Old 24-08-2018   #2
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Re: Guide: Renewing a gear shifter seal
Please post Guides in the appropriate section - https://www.fiatforum.com/guides/
Eklipze3k is offline
Closed Thread
Thread Tools
(S) gear shifter Skathomas94 Punto (Mk2/2b) 2 07-05-2014 18:55
(G) renewing the gear rod rubber bushes Tony M Panda (Classic) 12 06-08-2006 18:52
