Hi. I'm having problems with the above car...
Will not start, will not crank.
On first turn of the key it does nothing other than beep and show errors for ABS, POWER STEERING, AIRBAG and everything else.
Immobiliser light stays on, as does steering light.
I've connected to MES and I can connect to abs, steering , body , everything except ENGINE.
Ive checked all earth straps ( ecu,gearbox,alternator) and all are good.
I've checked, and found corrosion on the largest connector on ma in fuse box under the bonnet, cleaned up and sprayed contact cleaner on them all. So fairly confident there's a good connection now.
But still it refuses to start.
Anything else I'm missing?
