Technical Can't open rear door from inside or outside!!
Maru2604
North London
My friend has a problem when her outside door handle wasn't working but you could open the door from the inside.
Someone who had NO idea what they were doing thought they would be able to fix this issue by ACTIVATING the child lock???
So now the door won't open from the inside or outside!! :eek: :eek: :eek:
I need to get that door open and fixed. Please help!
I think the door needs to be opened in order to access the bottom screws :-(
This is a known problem, I got the problem too, i got a black GP, every time the sun shines at the left rear door it is impossibly to open it, try to cool the door using water, that might help.
There is a video how to fix it at YouTube. Search for "Fiat Grande Punto back doors jammed".
That was my comment to the previous answer (the tuto link)...
I am really afraid that You will have to use brute force to open your rear door, unless the central locking system still works ?
BRs, Bernie
On the YouTube video I watched yanking on the door handle while pushing on the top of the door seems to open it and the cure is only a bodge but it doesn't make clear which of the two parts of the mechanism is worn out ,however by looking on e bay the amount door handles one seller has sold I suspect it's the handle part that needs replacing.
