Hi all i have a 2008 Punto Active ,1.2 48kw engine,41000 miles on the clock and owned by me for the last 6 months,it has a dealer service history from new, it appears to have flat spot on the throttle,engine starts ok and idles steadily when cold at 1100 rpm and 800 when warm,the flat spot is only apparent when the smallest amount of throttle is applied and acceleration after that is ok as more acceleration is applied,but once road speed has been achieved,say 30 or 40 mph,the flat spot can then be felt as a steady speed is maintained.a kind of buffering effect,but if the throttle is released a quite violent transmission judder will be felt,as if the throttle has snapped shut but then comes back to a perfect idle.
I have had new spark plugs fitted and the HT leads checked,(replace if required all ok)and also a new air filter,the breather hoses to the air box have been removed and cleaned out.
My garage who i trust thinks it may be the throttle assy electronics not reading properly,his explanation to me was imagine a rotor with a dead segment, i can see that ok.
I found a good video from the USA of this on a US ford,they list it as replacement chip, not a complete throttle assy.
Do the techies on here think it may be a complete throttle assy as a cure?
I assume that the controlling chip for the stepper motor is not a spare part?
Or cannot be reset?
No fault codes are displayed or recorded and the tachometer stays rock steady.
Your thoughts gentleman.
Or cannot be reset?
