Hi advice needed the engine management light comes on then goes off but the car sort off jumps a little when driving and has just cut out while driving not every day but a couple of times a week it's done it ?
Hi the code reader has found 2 codes PO105 and PO106 which says manifold barometric pressure so do I need a mechanic is the car repairable as I wouldnt have a clue .
It could possibly be your MAP sensor needed a clean, or replacement (£50)
Which (on the 1.9) is very easy to do, one bolt holding it in, pull out, replace
