Old 11-09-2016   #1
Battery Light
Hello,
Had this problem for a few months now, and wanting some advise on it. I have a 2008 Grande Punto 1.4.
Sometimes when I start my car, the battery warning light comes on and my power steering isn't on. Once I restart my car, everything is fine again. It doesn't always happen, maybe once a week.
Any ideas what could cause this?
Browneyadz is offline Reply With Quote Quote
Old 11-09-2016   #2
flisko has donated!
Re: Battery Light
check battery charging voltage when car is on
flisko is offline Reply With Quote Quote
Old 12-09-2016   #3
Greece
Re: Battery Light
Quote Originally Posted by Browneyadz View Post
Hello,
Is the alternator an original part or an aftermarket one?
cmosfxx is offline Reply With Quote Quote
Old 12-09-2016   #4
Quote Originally Posted by cmosfxx View Post
I believe it is an aftermarket one. Would have to check my paperwork for the car when I get home. I had quite a bit of work done on the car about 4-5 months ago, that's when the problem started.
Old 12-09-2016   #5
Quote Originally Posted by flisko View Post
I will give this a check. Any idea what the voltage should be?
Old 12-09-2016   #6
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
Re: Battery Light
Voltage with the engine running should be around 14-14.5 volts
Current Garage
Mine: 2008 BMW 120d Coupe Stage 2 Mapped
Hers: 2007 Renault Megane 1.6 VVT Auto Dynamique
MrDerv is offline Reply With Quote Quote
Old 12-09-2016   #7
Greece
Re: Battery Light
It's a classic issue with aftermarket alternators.
The only solution is to replace it with an original.
Old 12-09-2016   #8
flisko has donated!
Re: Battery Light
(T) Punto POP red battery light....battery is charging. Eireannbaker Other Fiats 3 10-11-2016 13:22
(T) battery light big bear Grande Punto 5 07-07-2016 12:31
(T) Battery warning light "on" even with new battery and alternator fitted ! Nigel1 Grande Punto 0 06-08-2013 23:56
(T) Seicento Sporting 1108 Battery Not Charging Battery Light On SmithSeicento Cinquecento / Seicento 0 30-08-2012 00:02
(T) New Battery... ABS Light, Battery Light and Power steering light on...? Hamilton Cinquecento / Seicento 9 19-12-2010 15:18
