Our test will definitely not pass a car that doesn't meet legal criteria, of course they have to test for the particular trait first!!!!!! Common sense will tell you that it can't fail something that isn't required to be tested or examined, then again common sense isn't that common. Don't forget that the VW case was specifically designed to fool the test equipment used.
What is the difference between a maintenance check and a roadworthiness check? , The idea of any statutory test is to check that a vehicle is safe to drive on the public road. I'd hate to have your idea enshrined in law, prosecuted for not changing your oil perhaps
