im Axle Specialists
Old 30-08-2013   #1
HELP Window motor working but window not moving!
Just fitted a window deflector and after putting the window up, it was a squeeze then it stopped moving. The window stopped and it sounded like parts from the windows mechanism fell apart. Like bolts in a washing machine. Currently tapped the window over going to look at it soon.
RapidNova is offline Reply With Quote Quote
Old 30-08-2013   #2
Cadabena has donated!
Re: HELP Window motor working but window not moving!
I've changed the regulator before, it's a fairly simple mechanism, you can take your door card off and have a look without worrying about opening a can of worms. Does the window move at all if you try forcing it down, or slip down by itself for that matter?
Cadabena is offline Reply With Quote Quote
Old 30-08-2013   #3
Took the door card off, the pulley system has slipped off it's wheel. Should be easy to fix but for now I've just jammed the window in place. It's solid and water tight.
Likes Cadabena liked this post
Old 31-08-2013   #4
Glad to hear it's nothing serious. Hope the repair goes well
Old 31-08-2013   #5
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by RapidNova View Post
......but you can't go to the MacDonalds drive thru
(T) Window Motor MickeyBravo Bravo / Brava 6 04-07-2011 21:34
(T) 1.6 Window Motor Hobgblin Sedici 5 14-01-2011 10:53
(G) Working Window! Crachat Barchetta 14 11-02-2010 21:56
(T) Window not working?? MickeyBravo Bravo / Brava 13 23-03-2009 15:58
(T) Window motor (again?) Rustbucket Barchetta 6 26-09-2007 12:51
