Technical Front suspension clunk
Philjay51
Hi, I guess I am being a bit lazy, but to save me time can you guys help me.
My wife's GP has developed a clunk on the front near side. It has got progressively worse recently. What is the most likely cause, I cannot see any play in the top mount, so I am guessing drop link or outter ball joint?
I've had this problem ages,
Most common reasons on grande punto for knocking at front are shocker top bearings collapsing - cheap fix
Also known fault is steering rack bushes - not a cheap fix
I've done both and no joy, like u say drop links and cv boot could cause it, whack it on full lock and drive in a circle and see if it repeats that'll be an indicator
Having a similar problem at the moment. Was it only making the sound at low speeds and whilst turning? During parallel parking for example.
