Hi, I have an 06 Grande Punto which I've serviced myself but many times now, the oil filter O ring has popped out and oil has squirted everywhere! It says 25NM on the top of the housing but I do not have a torque wrench. There is also an arrow that says 'Drain'. I have done the cap hand tight plus 1/8, 1/4, turn or more and each time the O ring has come adrift and oil has squirted everywhere.
If I do it much tighter the O ring starts coming adrift even before I tun on the engine. 1/2 turn and the O ring is visibly hanging off.
I've now got another O ring in case the first has been damaged from over tightening. But how tight should it be? And is the 'Drain' arrow supposed to line up with anything?
