thank you for your reply,my punto is 2007 and a great car but every now and then it throws a wobbly and this radiant warning happens,i turn my engine off & on and it goes ok,i will check the things you suggest and let you know many thanks rayo.
Sorry to reignite an old thread but did anyone get this solved?? And also could a dodgy starter motor cause this warning to flash up at all?? I know it’s not the battery because it’s new and I’ve had my glow plugs tested (all fine) and glow plug relay is new...my partner thinks it’s the starter motor and I’m thinking it may be alternator, though this was also changed just 4 years ago (2015)?? I’ve got a 2007 1.9 mjet, 96000 miles and starting issues...though this excess fluid temp flashes up after the car is warmed mostly
