D4nny8oy
Established member
which cylinders do you drop the rods in Danny and do you align them on the descent or assent? (might as well add it to my guide in case someone has a snapped belt and needs to reference the piston strokes as you get a 2 turns of the crank shaft to one of the cam )
The rods go in cyls 1 & 2 (counting from cambelt-end), and the pistons are in the correct place when level with number 1 piston travelling down. If you're doing it with everything still in place, you'll normally tell when it's right because the compression will first spit the rod out of cyl 2, then cyl 1... usually into your face if you're leaning over the engine.
