andipunto
Member
Hi guys, for those who saw my last post about intermittent timing sensor fault I have had fiat look at it and have been told it is not as straight forward as first thought!
They have said that to get at the cam sensor the whole cam system needs to be removed which would mean removing and refitting the belt which may cause it to stretch which could cause it to go later on so they recommended I have the cam belt changed at the same time even though its only done 40k!
And instead of just having the sensor to pay for (£72) plus labour and vat it will now turn in to a couple of hour job costing atleast £500 for labour fitting new cam sensor and belt if I choose to do what they say.
Has anyone had cam sensor removed and found an easier way or had a non fiat garage work on it as I don't want to pay out £500
Thanks guys.
Thanks guys.
