Old 23-05-2012   #1
Question Advice Trace Reversing Light Cable or Light for suitable connection
this only my second post so bare with me.
im trying to fit a reversing camera that fits in the registration plate slot i can do this part however when it comes to connect the reversing camera power to the reversing light cable im not sure how to do this i would rather do a temporay method one that can easily be removed and thats connected inside the car. so any suggestions or places where the reversing light cable connects up so i could use a spade fittings or loop to connect to it or worse comes to worse if i use a scotch lock do these break the wire completely when removed.
murray670 is offline Reply With Quote Quote
Old 23-05-2012   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Advice Trace Reversing Light Cable or Light for suitable connection
simple to find in reality
remove boot trim along the back of the boot (2 pozi screws and the big torx one the boot popper sits against) and the rubber boot seal......
and pull it upwards (its on clips)
then locate the rubber grommet behind it
go down under the bumper and feel for the reverse light cables from the reverse light there are 2 + and - obviously
give them a wiggle and feel the cables in the boot as to which 2 they are....
then use a multimeter or test lamp with a spear tip to find live
i'd just scotch lock it to the correct wire when removed just wrap the cable in tape if fitted correctly it wont cut into the wire
Oh and welcome to the forum
Massive gash
Just a little touch up
(G) Reversing light(s) - one or two gadgetmind 500 16 04-04-2011 18:13
(G) Reversing light Fiatpuntomk2b Punto (Mk2/2b) 13 15-02-2011 14:51
(G) No reversing lights / abs light / warning light Scudo06 Scudo 0 23-12-2010 15:44
(G) Help ..need a reversing light roymck Barchetta 3 03-09-2008 13:58
(G) Reversing Light Donny XP Bravo / Brava 1 16-03-2007 09:38
