im Axle Specialists
Old 28-01-2012   #1
1.4 t-jet engine
Sorry if this has been covered before. I've been looking at the grande punto sporting 1.4 t-jet and whats the difference between the abarth 500/grande punto.
thanks
PhillRC is offline Reply With Quote Quote
Old 28-01-2012   #2
MKoers has donated!
Netherlands
Re: 1.4 t-jet engine
It's a different Fiat model
MKoers is offline Reply With Quote Quote
Old 28-01-2012   #3
im on about the engine in the 1.4 t-jet, is the t-jet sporting different engine(block,internals,turbo,ecu,ect ) to the abarth models.
sorry if i worded it wrong :/
Old 29-01-2012   #4
Quote Originally Posted by PhillRC View Post
The block is shared but the abarth has a larger turbo than the sporting t-jet. I'm not sure about con-rods, pistons, etc.
jameshobiecat is offline Reply With Quote Quote
Old 29-01-2012   #5
Boost-Tastic!
DlightSwitch's Avatar
Trader Rating: 1
DlightSwitch has donated!
Star Cannon Champion
The block is exactly the same. The Sporting T-Jet uses a different turbo (VL37), compared to the Abarth 500, which uses the VL38 turbo, and the Abarth GP uses the VL36 turbo.
When you get into the esseesse range however, the Abarth 500 & Grande Punto both use a larger Garett turbo, with bigger injectors and different boost sensors.
^^ Click for my Members Motors thread ^^
My YouTube Channel!
DlightSwitch is offline Reply With Quote Quote
Old 29-01-2012   #6
Greece
+ t-jet has shorter duration cams than the abarths. Everything else is the same (except of the ss)
Likes DlightSwitch liked this post
Alfa 156 1.6 FL
Alfa 146 1.7 16v boxer
Fiat GP 1.4 t-jet
tazjet is offline Reply With Quote Quote
Old 29-01-2012   #7
thanks for all the help guys
about 1.4T-JET engine Nina Lets Talk FIAT 11 04-12-2016 00:19
(Tu) T-Jet Engine Mawso91 Grande Punto 5 11-05-2011 23:04
(T) 1.9 M-Jet engine code Mattyk Grande Punto 2 24-09-2009 13:08
(T) T-jet engine schema death_paladin9 Bravo 1 09-08-2008 20:33
