Problem...
Hello to all from Greece. I own a grande punto 1.4 16V. After some problems with a dead VARTA battery, I purchased an new but cheaper one (i know, i know but... no money, no honey). Everything was working fine untill a week ago. Many times when I switch on the engine I get the ESP/ASR/Hill Holder fault. I have to turn the engine off and on many times untill I get no fault. Apart from that 2 times this week I lost all the power steering (and the fault for this came on). I had to turn the engine off and then on and everything was fine.
What I checked...
I checked the battery with a multimeter and it looks fine. When the engine is off it reads 12.9V and when working it reads constantly 14+ V. So the battery and the alternator is ok. BUT! I saw a major corrosion at the base of the battery and I am totally sure it's from the new battery, not the old one.
Any help...
Do you think the battery is defective? OK obviously its devective cause of the leak and needs to be replaced. But can it cause problems at the electronics so that the faults come up? And if not... what do I have to look? I checked the fuse box next to the battery and looks totally dry and with no humidity.
Sorry for my english
What I checked...
Any help...
