- Feb 24, 2009
- 95
- 37
Driving along the motorway when i though I started to smell a very hot smell. wasnt sure if it was coming from my car or not. The temperature light then went red and the temperature needle hit the ceiling. I luckily was only a couple of hundred yards from the motorway exit so pulled off and stopped. the engine was still running at this point but i turned it off. Had a quick look under the bonnet noticing that my coolant was boiling over. I guessed at first I had blown a pipe or something. so let it cool down and tried to restart it, without any luck. recovery boys came out and have diagnosed the fault to be the fact the timing belt has snapped.
I now dont know what to do. If the timing has gone out then the valves and pistons are probably gubbed. So my guess is a second hand block could be cheaper.
Any ideas on what to do or where to get parts etc?
Cheers in advance.
Cheers in advance.
