Technical Help please
neave4246
scotland
Hi I have just noticed that there is a thumping sound when I turn the wheel in slow movement or stationary. It like sounds like it coming from front wheel any. Suggestions what problem could be
Hi the car is a 2008 and sounds like it from the front suspension it a nit a vibrating thump when you slightly turn the wheel
Would this part be dear and is it due to pot wholes or just old age also could it be tracking that not helping problem
as you can see from the pics in the guide water and grit gets in making the bearings stick or seize the part is £20 ish each
just labour on top could always try getting a quote from an Independent garage also have a good look at the springs in case they are broken
