Hi all - first poster 'on the want' Sorry!
My '56 Grande Punto is now out of warranty and has developed a problem with the power steering. It makes a grinding noise when it goes past 12 o'clock. This has been going on for a fortnight. On two occasions I have started it up to get the message 'Have power steering checked' and I only have mechanical steering. However turning it off and on again clears it. I am led to believe that this is a known problem which is intermittent at first and becomes permanent. I understand that the solution is a replacement steering rack at around £700.
I do know however that the vehicle was subject to two recalls:
R/007/033 Steering Column may become disconnected
and
R/2009/130 Steering may fail
It may have been in for the first one as it was on Fiat's forecourt at the time of that recall, however it certainly didn't go in for the second as I had it. I didn't receive notification of the recall as I moved house and didn't inform DVLA immediately.
My question is:
What should I expect from Fiat and what is the best way to approach the issue with them?
Thanks for any advice!
and
My question is:
